跳转到主内容
Toshiba Satellite L455-S5975 WiFi Card Replacement
你所需要的
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: 步骤 1 中的图像 1,1
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 2 中的图像 2,2
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 3 中的图像 3,3
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 4 中的图像 1,1
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L455-S5975 WiFi Card Replacement: 步骤 5 中的图像 2,2
    • Gently remove the wifi card from the laptop.
结论
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
2等其他人完成本指南。
Dylan Baker
于03/11/14注册
188 声望
撰写一个指南
团队
UMD team 2 UMD team 2 的会员
Community
4 名成员
创作了1篇指南
一条评论
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,241
