跳转到主内容
Toshiba Satellite L455-S5975 Logic Board Replacement
你所需要的
  1. Toshiba Satellite L455-S5975 Logic Board Replacement, Keyboard: 步骤 1 中的图像 1,2 Toshiba Satellite L455-S5975 Logic Board Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 4 中的图像 2,2
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
  5. Toshiba Satellite L455-S5975 Logic Board Replacement, Fan: 步骤 5 中的图像 1,2 Toshiba Satellite L455-S5975 Logic Board Replacement, Fan: 步骤 5 中的图像 2,2
    • Flip the laptop over to access the battery.
    • Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
  6. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 6 中的图像 1,1
    • Remove the twelve 10mm screws with a Phillips #00 screwdriver.
    • Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
  7. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Remove the three 4mm screws with a Phillips #00 screwdriver.
  8. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 8 中的图像 1,1
    • Flip the laptop over so it's in the right-side-up position.
    • Lift the grey plastic casing up and unhook any wires attached to the casing.
    • Remove the five 10mm screws, each with a label 'F10' next to them.
  9. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 9 中的图像 2,2
    • Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
    • Disconnect the thin red wire on the right side of the motherboard.
  10. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 10 中的图像 1,1
    • Remove the two 6mm screws with a Phillips #00 screwdriver.
  11. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 11 中的图像 2,2
    • Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
    • Remove the fan.
  12. Toshiba Satellite L455-S5975 Logic Board Replacement, Logic Board: 步骤 12 中的图像 1,1
    • Remove the following with a Phillips #00 Screwdriver:
    • Six 7mm Phillips Head screws
    • One 5 mm Phillips Head screw
    • Remove the LCD screen tab
  13. Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 13 中的图像 1,2 Toshiba Satellite L455-S5975 Logic Board Replacement: 步骤 13 中的图像 2,2
    • A red wire connects the motherboard to the computer, so release the wire by pulling it straight out.
    • After all the screws are removed, lift the motherboard up and away from the earphone jacks that are located at the front of the laptop.
结论
另外一个人完成了本指南。
Mike Kennedy
于04/18/13注册
160 声望
创作了4篇指南
团队
Cal Poly, Team 2-21, Maness Spring 2013 Cal Poly, Team 2-21, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G21
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 3,052
