跳转到主内容
Toshiba Satellite L455-S5975 Keyboard Replacement
你所需要的
  1. Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L455-S5975 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
结论
另外一个人完成了本指南。
Mike Kennedy
于04/18/13注册
160 声望
创作了4篇指南
团队
Cal Poly, Team 2-21, Maness Spring 2013 Cal Poly, Team 2-21, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G21
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 17
总计 2,376
