简介
In this guide we will teach you how to replace the fan on your laptop. Be sure to read the Satellite L455-S5046 Troubleshooting Guide to see if a replacement is necessary.
你所需要的
Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
Insert your finger under the middle tab and lift the battery out.
Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
