跳转到主内容
Toshiba Satellite L455-S5046 The Fan Replacement
你所需要的
  1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite L455-S5046 The Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 The Fan Replacement, Fan: 步骤 2 中的图像 1,1
    • Start on the back and unscrew the 12 Phillips #0 11-mm screws holding the back cover down.
  3. Toshiba Satellite L455-S5046 The Fan Replacement: 步骤 3 中的图像 1,1
    • Pop off the hard drive cover, and then unscrew the four 11-mm Phillips #0 screws.
  4. Toshiba Satellite L455-S5046 The Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L455-S5046 The Fan Replacement: 步骤 4 中的图像 2,2
    • Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
    • Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
    • Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
  5. Toshiba Satellite L455-S5046 The Fan Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L455-S5046 The Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the connector between the fan and the laptop by pulling gently to the left.
    • Remove the two indicated 11-mm Phillips #0 screws.
  6. Toshiba Satellite L455-S5046 The Fan Replacement: 步骤 6 中的图像 1,1
    • Now gently lift the fan and pull out.
结论
Daryl Spurgeon
于01/10/17注册
610 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 263
