跳转到主内容
Toshiba Satellite L455-S5046 Optical Drive Replacement
你所需要的
视频概述
  1. Toshiba Satellite L455-S5046 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
  2. Toshiba Satellite L455-S5046 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Lift the plate and gently pull it away from yourself, until it is removed.
  3. Toshiba Satellite L455-S5046 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
  4. Toshiba Satellite L455-S5046 Optical Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L455-S5046 Optical Drive Replacement: 步骤 4 中的图像 2,2
    • The optical drive is partially visible and push it to the right.
    • The optical drive should pop out on the right side, and you can gently pull it out.
结论
Daryl Spurgeon
于01/10/17注册
610 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 180
