跳转到主内容
Toshiba Satellite L455-S5046 Hard-drive Replacement
你所需要的
  1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 Hard-drive Replacement, Hard-drive: 步骤 2 中的图像 1,1
    • Locate the hard drive in the upper right corner on the back of the computer.
    • Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
  3. Toshiba Satellite L455-S5046 Hard-drive Replacement: 步骤 3 中的图像 1,1
    • Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
结论
Daryl Spurgeon
于01/10/17注册
610 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 287
