跳转到主内容
Toshiba Satellite L45-S7423 Wireless Card Replacement
你所需要的
  1. Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: 步骤 4 中的图像 1,3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: 步骤 4 中的图像 2,3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: 步骤 4 中的图像 3,3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 5 中的图像 3,3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: 步骤 6 中的图像 1,3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: 步骤 6 中的图像 2,3 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: 步骤 6 中的图像 3,3
    • Remove the black and the white antenna wires attached to the wireless card.
    • Using a plastic removal tool, gently pop the connections apart.
  7. Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 7 中的图像 2,2
    • Remove the screws holding the wireless card in place.
    • Two 3.6 mm Phillips screws.
  8. Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 8 中的图像 1,1
    • The wireless card will automatically pop up allowing for easy removal.
  9. Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L45-S7423 Wireless Card Replacement: 步骤 9 中的图像 2,2
    • Pull to remove the wireless card.
结论
2等其他人完成本指南。
Stephen Sippel
于04/16/13注册
194 声望
创作了9篇指南
团队
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G54
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 2,204
