简介
This guide will demonstrate to the user how to remove and install new RAM into their laptop. RAM is often upgraded on the laptop to increase performance and is therefore made easy to replace.
  1. Make sure the battery lock switch is switched to the unlocked position. The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock. The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
    • Make sure the battery lock switch is switched to the unlocked position.
      • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Slide the battery release switch to the left. The switch is spring loaded, so you must hold the switch in place while removing the battery.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Using a finger, lift up the battery. The battery release switch must be held in place.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Remove the 5 Phillips screws holding the panel in place. These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss. These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  6. Use a finger to remove the panel by lifting up on the provided removal tab. Use a finger to remove the panel by lifting up on the provided removal tab. Use a finger to remove the panel by lifting up on the provided removal tab.
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  7. Pull apart the two tabs holding the RAM in place. Pull apart the two tabs holding the RAM in place. Pull apart the two tabs holding the RAM in place.
    • Pull apart the two tabs holding the RAM in place.
  8. Upon release, RAM will automatically pop up.
    • Upon release, RAM will automatically pop up.
  9. Gently pull on RAM to remove. Gently pull on RAM to remove. Gently pull on RAM to remove.
    • Gently pull on RAM to remove.
结论
Stephen Sippel
于2013年04月16日注册
167 信誉积分
创作了9篇指南
团队
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G54
4 名成员
创作了9篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 1,049
