跳转到主内容
Toshiba Satellite L35-S2174 Keyboard Replacement
你所需要的
  1. Toshiba Satellite L35-S2174 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 4 中的图像 1,1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,2 Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 8 中的图像 2,2
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
结论
Amani Mitchell
于10/18/16注册
401 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-4, Catania Fall 2016 UMass Dartmouth, Team 1-4, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 9
总计 340
