跳转到主内容
Toshiba Satellite L35-S2174 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite L35-S2174 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Hard Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L35-S2174 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Hard Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L35-S2174 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Use a J1 screwdriver to unscrew the two circled screws. The screws will remain attached to the plastic panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 Hard Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L35-S2174 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Slide the hard drive to the left to detach it from the computer.
    • Lift the hard drive from the computer.
结论
Amani Mitchell
于10/18/16注册
401 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-4, Catania Fall 2016 UMass Dartmouth, Team 1-4, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 13
总计 565
