当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate the two sliding battery locks on the underside of the laptop.
Locate the right battery lock and slide it to the right.
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Remove the battery from the laptop.
Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
Remove the RAM module by pulling it out at the angle it was rotated to.
If you want to replace the second RAM module, apply steps 2 and 3 to do so.
取消:我没有完成这个指南。
与3其他贡献者
于03/26/14注册
217 声望
创作了2篇指南
徽章: 5
+ 2更多徽章
CLEM-BENSON-S14S1G2
3 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 412
