跳转到主内容
Toshiba Satellite L305D-S5950 RAM Replacement
你所需要的
  1. Toshiba Satellite L305D-S5950 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 2 中的图像 2,2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 3 中的图像 2,2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 RAM Replacement, RAM: 步骤 5 中的图像 1,3 Toshiba Satellite L305D-S5950 RAM Replacement, RAM: 步骤 5 中的图像 2,3 Toshiba Satellite L305D-S5950 RAM Replacement, RAM: 步骤 5 中的图像 3,3
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  6. Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 6 中的图像 2,2
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  7. Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 7 中的图像 2,2
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  8. Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite L305D-S5950 RAM Replacement: 步骤 8 中的图像 3,3
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
结论
To reassemble your device, follow these instructions in reverse order. When placing the RAM chips in, push them down until the levers snap into place after inserting them into the slot.
Ricky Baker
于03/26/14注册
217 声望
创作了2篇指南
团队
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 的会员
CLEM-BENSON-S14S1G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 412
