跳转到主内容
Toshiba Satellite L305D-S5900 Storage Drive Replacement
你所需要的
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L305D-S5900 Storage Drive Replacement: 步骤 3 中的图像 2,2
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
结论
Sing Yang Cheng
于10/20/16注册
501 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 353
