跳转到主内容
Toshiba Satellite L305D-S5900 RAM Replacement
你所需要的
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L305D-S5900 RAM Replacement: 步骤 2 中的图像 2,2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L305D-S5900 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L305D-S5900 RAM Replacement: 步骤 3 中的图像 3,3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
结论
Sing Yang Cheng
于10/20/16注册
501 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 16
总计 266
