跳转到主内容
Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
你所需要的
  1. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement, Optical Drive (Disk Drive): 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 步骤 2 中的图像 2,2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 步骤 3 中的图像 2,2
    • The 5.3 mm Phillips #1 screw boxed in red is located on the right panel that house the RAM on the underside of the computer.
    • Remove the screw securing the drive on the plastic edge.
  4. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 步骤 4 中的图像 1,1
    • Use a screwdriver or a metal spludgers to push the metal piece attached to the drive in the direction of the drive opens until the drive pops out of its socket.
  5. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 步骤 5 中的图像 1,1
    • Fully remove the drive by pulling it all the way out of its socket.
结论
Sing Yang Cheng
于10/20/16注册
501 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 8
总计 637
