跳转到主内容
Toshiba Satellite L305D-S5900 Keyboard Replacement
你所需要的
  1. Toshiba Satellite L305D-S5900 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly.
    • The plastic strip boxed in red is located above the keyboard of the computer.
  2. Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 2 中的图像 3,3
    • There are three points of contact boxed in red needed to release located at the far left, the far right and the middle of the plastic strip.
    • Remove the plastic strip from one far end progressively towards the other end using a metal spludger.
  3. Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.3 mm Phillips #1 screws that are beneath the strip.
    • The screws located at the far left and far right when the plastic strip is removed.
  4. Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Use the metal spludger to push the keyboard in the direction of the track pad and then lift the keyboard up.
    • Be careful not to pull too fast as there is still another cable attaching the keyboard.
  5. Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 步骤 5 中的图像 3,3
    • There are two tab boxed in red is located at each side of the ZIF (zero insertion force) connector.
    • Use a metal spludger to push the tab upward in order to release the cable ribbon.
    • Carefully pull out the ribbon cable from the ZIF (zero insertion force) connector.
结论
Sing Yang Cheng
于10/20/16注册
501 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 349
