跳转到主内容
Toshiba Satellite L305D-S5900 Battery Replacement
  1. Toshiba Satellite L305D-S5900 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning dissassembly.
    • The left-hand switch and right-hand switch boxed in red located at the bottom on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Battery Replacement: 步骤 2 中的图像 1,1
    • Set the right-hand switch near the battery into the unlock position (move switch from left to right).
  3. Toshiba Satellite L305D-S5900 Battery Replacement: 步骤 3 中的图像 1,1
    • Set and hold the left hand switch near the battery into its unlock position (move switch from right to left).
  4. Toshiba Satellite L305D-S5900 Battery Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L305D-S5900 Battery Replacement: 步骤 4 中的图像 2,2
    • While both switches are in their unlocked positions, use a plastic opening tool or your fingers to lift out the battery at the indent between the switches.
    • The right hand switch regardless of initial position will stay or return to the unlock position when a battery is placed back in the slot. To avoid any mishaps, be sure to set the switch back into the lock position while any battery is plugged in.
结论
Sing Yang Cheng
于10/20/16注册
501 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 10
总计 238
