跳转到主内容
Toshiba Satellite L305D-S5895 RAM Replacement
你所需要的
  1. Toshiba Satellite L305D-S5895 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Toshiba Satellite L305D-S5895 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • You will use your P0 screwdriver attachment to undo this screw.
    • Undo the screw using the screwdriver.
  2. Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 2 中的图像 1,1
    • Use your finder to pry the cover up.
    • You will feel the cover pop up. This is normal.
  3. Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 3 中的图像 3,3
    • You should now be able to see two silver tabs.
    • Use two fingers to push these tabs away from each other.
    • The RAM stick should pop up at about a 30 degree angle.
  4. Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 4 中的图像 1,1
    • You should now be able to remove the first RAM stick by pulling it out in the direction of the long elevated side.
  5. Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 5 中的图像 3,3
    • You should now be able to see the second pair of tabs for the second RAM stick.
    • The second RAM stick should now be sitting at about a 30 degree angle.
  6. Toshiba Satellite L305D-S5895 RAM Replacement: 步骤 6 中的图像 1,1
    • You can now remove this RAM stick by pulling on the long elevated side of the RAM stick.
结论
To reassemble your device, follow these instructions in reverse order. Make sure that you have the RAM stick in the correct orientation when attempting to put it back in place.
Daniel Matheson
于10/19/16注册
355 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 UMass Dartmouth, Team 2-8, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G8
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 243
