当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
Lift the keyboard up in order to remove the cable.
Notice the two white tabs on the compartment holding the cable.
Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
取消:我没有完成这个指南。
与4其他贡献者
于10/21/16注册
101 声望
撰写一个指南
徽章: 3
UMASSD-ISAACSON-F16S2G8
3 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 327
