跳转到主内容
修复你的物品
维修的权力
配件 & 工具
配件
没有特定配件。
  1. Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop. Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. Manta 螺丝刀工具包
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  4. After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop. Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  5. Lift the keyboard up in order to remove the cable.
    • Lift the keyboard up in order to remove the cable.
  6. Notice the two white tabs on the compartment holding the cable. Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire. Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
结论
Tyler GLick
于2016年10月21日注册
101 信誉积分
撰写一个指南
团队
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 UMass Dartmouth, Team 2-8, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G8
3 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 185
