跳转到主内容
Toshiba Satellite L305-S5955 Wireless Card Replacement
你所需要的
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: 步骤 1 中的图像 1,1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 6 中的图像 2,2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 1,3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 2,3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 3,3
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: 步骤 9 中的图像 1,1
    • Pull the card out vertically.
结论
Samuel Baker
于01/30/17注册
307 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Baechle Spring 2017 IUPUI, Team 1-2, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 796
