跳转到主内容
Toshiba Satellite L305-S5955 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Complete these steps in reverse order to insert hard drive back into laptop.
结论
2等其他人完成本指南。
Eric
于09/30/14注册
55 声望
撰写一个指南
团队
Ohio State, Team 1-2, Buehl Fall 2014 Ohio State, Team 1-2, Buehl Fall 2014 的会员
OSU-BUEHL-F14S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 985
