跳转到主内容
Toshiba Satellite L305-S5955 Fan Replacement
你所需要的
  1. Toshiba Satellite L305-S5955 Fan Replacement, Lock Tabs: 步骤 1 中的图像 1,1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 2 中的图像 1,1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Fan Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 5 中的图像 1,1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 6 中的图像 2,2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Fan Replacement, Fan: 步骤 7 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement, Fan: 步骤 7 中的图像 2,2
    • Once the battery is removed, locate and unscrew the 3.2 mm PH1000 Phillips head screws that are underneath the battery.
  8. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 8 中的图像 2,2
    • Unscrew all 6.7 mm PH1 Phillips head screws marked "F6" located on the back of your computer.
  9. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 9 中的图像 2,2
    • Remove the wire and ribbon by gently pulling them out from the motherboard.
  10. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 10 中的图像 2,2
    • Pry open and remove the protective casing by using any flat-headed utensil at the hinges to expose the motherboard. You should hear it click when it unlatches.
    • Repeat this same process on the other hinge.
    • Be gentle when prying open this component to avoid damaging your laptop.
  11. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 11 中的图像 1,1
    • Unscrew all screws attached to the motherboard including the 3 following types of screws: Phillips head PH1 4.9 mm, 10.7 mm, and 4.3 mm.
  12. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 12 中的图像 1,1
    • Remove all wired components that are connected to the motherboard preventing its removal.
    • Some of these components need specific steps to disconnect them to avoid damages.
  13. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 13 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 13 中的图像 2,2
    • Push the head of the ZIF ribbon cable gently using a spudger until it detaches from the connector.
    • ZIF cable means zero insertion force. This means that no force is needed to plug in or remove the cable.
    • Repeat this step for the second ZIF ribbon cable.
  14. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 14 中的图像 3,3
    • Pull the cable straight out from the connector to disconnect it.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
    • Push each side of the sliding connector using the tip of a spudger carefully.
    • Repeat previous step for bottom part of the sliding connector.
  15. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 15 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 15 中的图像 2,2
    • Pry the antenna cable connector straight up from the board using the flat edge of a spudger.
    • Repeat the previous step for the second antenna cable.
  16. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 16 中的图像 1,1
    • Slide out the disc drive so that it is not obstructing the removal of the motherboard.
  17. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 17 中的图像 1,2 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 17 中的图像 2,2
    • Place both hands on the front and right side of the motherboard, using your thumb and index finger, pinch it off of the latches.
    • Lift the motherboard up once the latches are detached.
  18. Toshiba Satellite L305-S5955 Fan Replacement: 步骤 18 中的图像 1,3 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 18 中的图像 2,3 Toshiba Satellite L305-S5955 Fan Replacement: 步骤 18 中的图像 3,3
    • Flip the motherboard over and locate the fan.
    • Unscrew the two Phillips head PH1 4.3 mm screws connecting the fan to the motherboard and pull up on the 3 colored wires until they are detached.
    • Lift the fan up and slide it out from the motherboard. Now you are ready to put in your new fan.
结论
Samuel Baker
于01/30/17注册
307 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Baechle Spring 2017 IUPUI, Team 1-2, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 472
