当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place the laptop upside-down with the display hinges facing away from you.
Slide the latch for the left battery bay to the left.
Slide the latch for the right battery bay to the right and hold.
Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
This is a captive panel screw and remains with the cover.
Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
The RAM card should pop up at an angle.
Pull the RAM card away from the computer.
Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与13其他贡献者
于04/17/13注册
130 声望
创作了9篇指南
徽章: 13
+ 10更多徽章
CPSU-AMIDO-S13S3G49
4 名成员
创作了19篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 14
总计 831
