跳转到主内容
Toshiba Satellite L305-S5946 RAM Replacement
你所需要的
  1. Toshiba Satellite L305-S5946 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L305-S5946 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L305-S5946 RAM Replacement: 步骤 3 中的图像 3,3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  5. Toshiba Satellite L305-S5946 RAM Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L305-S5946 RAM Replacement: 步骤 5 中的图像 2,2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  6. Toshiba Satellite L305-S5946 RAM Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L305-S5946 RAM Replacement: 步骤 6 中的图像 2,2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  7. Toshiba Satellite L305-S5946 RAM Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite L305-S5946 RAM Replacement: 步骤 7 中的图像 2,2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 3-49, Amido Spring 2013 Cal Poly, Team 3-49, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G49
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 822
