简介
Use this guide to remove or install a motherboard on your Toshiba Satellite L305-S5946. It will be necessary to remove the motherboard to replace the GPU. This guide also acts as a prerequisite for the processor and cooling fan installation guides.
你所需要的
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
For the following steps, use a Phillips #1 screwdriver.
Remove the twelve 6-mm screws that border the bottom of the laptop.
Remove the 6-mm screw located in the lower middle of the device.
Remove the three 3-mm screws located in the battery bay.
Remove the one 4-mm screw located near the RAM.
Remove the four 6-mm screws from the two hinge pads using a Phillips #1 screwdriver.
For the following steps, use tweezers:
Remove the connector equipped with the black and white wire.
Remove the connector equipped with the black, green, red, yellow, and white wires.
Using your fingers, remove the large connector located at the top right corner of the motherboard, as shown.
Remove the power jack connector.
Remove the connector equipped with one red wire and one black wire.
Remove the connector equipped with red, yellow, green, white, and black wires.
Remove the large connector near the fan.
Remove the power jack cable and socket from its housing by pulling gently.
另外一个人完成了本指南。
