当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place the laptop upside-down with the display hinges facing away from you.
Slide the latch for the left battery bay to the left.
Slide the latch for the right battery bay to the right and hold.
Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Lift the hard drive cover using a non-marring iFixit opening tool.
This will expose the hard drive.
Slide the hard drive to the left using your fingers.
Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
取消:我没有完成这个指南。
4等其他人完成本指南。
与11其他贡献者
于04/18/13注册
346 声望
撰写一个指南
徽章: 11
+ 8更多徽章
CPSU-AMIDO-S13S3G49
4 名成员
创作了19篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 2,111
