本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove housing on the base of your Toshiba Satellite L305-S5946. Removing the housing gives you access to the motherboard, processor, power jack, fan, and LCD screen.
你所需要的
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
另外一个人完成了本指南。
