跳转到主内容
修复你的物品
维修的权力
商店
简介
Installing additional RAM modules will increase the performance of your laptop, and is relatively easy to do.
  1. Close the laptop lid and flip the laptop over.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Push the release button to the right. Hold the release button to the right and lift the battery out of its housing. Hold the release button to the right and lift the battery out of its housing.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Locate the RAM Module compartment on the bottom side of the laptop. Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place. Locate the notch on the screw side of the lid and lift to remove it.
    • Locate the RAM Module compartment on the bottom side of the laptop.
    • Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place.
    • Locate the notch on the screw side of the lid and lift to remove it.
  4. Push the metal tabs on the sides of the RAM outward and the RAM will pop up. Gently pull the RAM out. Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Push the metal tabs on the sides of the RAM outward and the RAM will pop up.
    • Gently pull the RAM out.
    • Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Gently apply pressure until the metal tabs on the sides click into place.
结论
3等其他人完成本指南。
Elliot Fiske
于2013年01月30日注册
36 信誉积分
撰写一个指南
团队
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G5
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 6,468
