跳转到主内容
Toshiba Satellite L305-S5875 LCD Screen Replacement
你所需要的
  1. Toshiba Satellite L305-S5875 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,1
    • Open the laptop so that you can see the screen.
  4. Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  5. Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  6. Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  7. Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  8. Toshiba Satellite L305-S5875 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Congratulations, you have just removed your screen!
结论
Now that you have removed the damaged screen, it is time to replace it with the new screen.
Follow these steps in reverse order to reassemble your laptop.
You have completed the LCD screen replacement guide for the Satellite L305-S5875. Great job!
2等其他人完成本指南。
Joshua Lessard
于03/11/14注册
128 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014 的会员
UMASSD-CALAWAY-S14S3G1
4 名成员
创作了6篇指南
一条评论
My problem is a little different; mine broke near the hinge on the left side. So I need to remove the whole thing from the hinge up. Help?
DBethke1959@GMail.com
dbethke_1959 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 15
总计 1,598
