跳转到主内容
配件
没有特定配件。
  1. 这个步骤还没有翻译 帮忙翻译一下
    Close the laptop lid and flip the laptop over.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. 这个步骤还没有翻译 帮忙翻译一下
    Push the release button to the right. Hold the release button to the right and lift the battery out of its housing. Hold the release button to the right and lift the battery out of its housing.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Open the laptop so the keyboard is facing you. Using your fingers, remove the thin plastic cover above the keyboard. Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. 这个步骤还没有翻译 帮忙翻译一下
    Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. 这个步骤还没有翻译 帮忙翻译一下
    Starting at the top, gently raise the keyboard enough to remove it from the socket. Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. 这个步骤还没有翻译 帮忙翻译一下
    Locate the data cable that is connected to the motherboard. Pull the white ZIF connector towards the screen to remove it.
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. 这个步骤还没有翻译 帮忙翻译一下
    With the black ribbon cable now disconnected, remove the keyboard from  its housing.
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
终点
3等其他人完成本指南。
Juan
于2013年01月11日注册
109 信誉积分
创作了3篇指南
团队
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G5
4 名成员
创作了5篇指南
It's not so easy to do step 3.
Texas Chick - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 4
总计 2,982
