跳转到主内容
Toshiba Satellite L305-S5875 Keyboard Replacement
你所需要的
  1. Toshiba Satellite L305-S5875 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Keyboard Replacement: 步骤 7 中的图像 1,1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
结论
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3等其他人完成本指南。
Juan
于01/11/13注册
109 声望
创作了3篇指南
团队
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G5
4 名成员
创作了10篇指南
一条评论
It's not so easy to do step 3.
Texas Chick - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 3,204
