本指南有最近更改,您可查看未经巡查的最新版本。
简介
If the hinges become loose from wear and tear or break, creating hassle when using the computer, on your Toshiba Satellite L305-S5875, this guide walks you through how to access and tighten, or replace as needed, the hinges on your Toshiba Satellite L305-S5875.
你所需要的
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Close your laptop and flip it over.
Remove the 13 screws using a Phillips #00 screwdriver.
另外一个人完成了本指南。
