跳转到主内容
Toshiba Satellite L305-S5875 Hinge Replacement
你所需要的
  1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 步骤 1 中的图像 1,3 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 步骤 1 中的图像 2,3 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  2. Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  3. Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 3 中的图像 2,2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  4. Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 4 中的图像 2,2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  5. Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 5 中的图像 1,1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  6. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: 步骤 6 中的图像 1,2 Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: 步骤 6 中的图像 2,2
    • Close your laptop and flip it over.
    • Remove the 13 screws using a Phillips #00 screwdriver.
  7. Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 7 中的图像 1,1
    • Gently disconnect the ribbon cable.
    • Gently disconnect the multicolored cable.
  8. Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 8 中的图像 1,1
    • Gently pull the top case from the bottom case of the laptop.
  9. Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L305-S5875 Hinge Replacement: 步骤 9 中的图像 2,2
    • Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
    • Both hinges shown, but replacing both may not be necessary.
    • Congratulations, you may now remove and replace your hinge!
结论
另外一个人完成了本指南。
Tyler
于03/11/14注册
208 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014 的会员
UMASSD-CALAWAY-S14S3G1
4 名成员
创作了6篇指南
一条评论
Will this work for a Toshiba satellite l655 model
ethanhunemuller - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 6,425
