跳转到主内容
Toshiba Satellite L305-S5875 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite L305-S5875 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Flip the laptop over so that you can see the back. Make sure that the volume scroller is closest to you when it is flipped over.
    • Locate the hard drive compartment. This is in the bottom left hand side of the laptop.
    • Remove the two 5 mm type-0 Phillips head screws that secure the door and save them to a safe location.
    • Remove the hard drive cover.
  4. Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • With the small door removed, find the black ribbon that is attached to the hard drive tray.
    • Carefully pull the ribbon to the left so that the hard drive tray slides out neatly.
  5. Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the four 4.2 mm type-0 Phillips head screws located on the side of the hard drive enclosure.
  6. Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L305-S5875 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Remove the hard drive from the tray.
    • Make sure that when you slide the tray back into place, that the ribbon remains easily accessible.
结论
David Zhuo
于01/11/13注册
35 声望
撰写一个指南
团队
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 2,343
