跳转到主内容
Toshiba Satellite L305-S5875 CCFL Tube Replacement
你所需要的
  1. Toshiba Satellite L305-S5875 CCFL Tube Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Open the laptop so that you can see the screen.
  2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 2 中的图像 2,2
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  3. Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 3 中的图像 3,3
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  4. Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 4 中的图像 3,3
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  5. Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 5 中的图像 3,3
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  6. Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 6 中的图像 1,1
    • Congratulations, you have just removed your screen!
  7. Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: 步骤 7 中的图像 1,2 Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: 步骤 7 中的图像 2,2
    • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
    • In addition to removing the screws, remove the tape on the edge of the screen.
  8. Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 8 中的图像 1,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 8 中的图像 2,3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 8 中的图像 3,3
    • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
    • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
  9. Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: 步骤 9 中的图像 2,2
    • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
    • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
结论
另外一个人完成了本指南。
Tyler
于03/11/14注册
208 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014 的会员
UMASSD-CALAWAY-S14S3G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 548
