跳转到主内容
Toshiba Satellite L15W-B1320 Battery Replacement
你所需要的
  1. Toshiba Satellite L15W-B1320 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Battery Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L15W-B1320 Battery Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L15W-B1320 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
结论
Elizabeth Zapata
于09/25/17注册
190 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 1,233
