跳转到主内容
Toshiba Satellite L15W-B1303 Touchpad Board Replacement
你所需要的
  1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: 步骤 1 中的图像 1,3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: 步骤 1 中的图像 2,3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: 步骤 1 中的图像 3,3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: 步骤 2 中的图像 1,3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: 步骤 2 中的图像 2,3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: 步骤 2 中的图像 3,3
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
  3. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Touchpad Board: 步骤 3 中的图像 1,1
    • Remove any pieces of tape securing the board.
    • Using your Phillips #0 screwdriver, remove both screws holding the board in place.
  4. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: 步骤 4 中的图像 1,1
    • Gently disconnect the cables that link the touchpad board to the rest of the laptop
    • Be careful when doing this. It can be easy to damage the components. If the connector seems stuck, try wiggling it; do not force it off.
  5. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: 步骤 5 中的图像 1,1
    • Remove the board from the laptop.
结论
另外一个人完成了本指南。
Yanchen Li
于01/22/20注册
121 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 351
