跳转到主内容
Toshiba Satellite L15W-B1208X Sound Board Replacement
你所需要的
  1. Toshiba Satellite L15W-B1208X Sound Board Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite L15W-B1208X Sound Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 3 中的图像 3,3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 4 中的图像 3,3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
  5. Toshiba Satellite L15W-B1208X Sound Board Replacement, Sound Board: 步骤 5 中的图像 1,2 Toshiba Satellite L15W-B1208X Sound Board Replacement, Sound Board: 步骤 5 中的图像 2,2
    • Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
  6. Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 6 中的图像 1,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 6 中的图像 2,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 6 中的图像 3,3
    • Using the ESD Safe Tweezers Blunt Nose gently pull on the plastic connector that attaches the speaker wiring to the soundboard to disconnect the soundboard from the laptop.
    • Gently pull the wire away from the soundboard using the ESD Safe Tweezers Blunt Nose.
  7. Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite L15W-B1208X Sound Board Replacement: 步骤 7 中的图像 3,3
    • Gently lift the soundboard out of the laptop.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 143
