跳转到主内容
Toshiba Satellite E45t-B4300 Speakers Replacement
你所需要的
  1. Toshiba Satellite E45t-B4300 Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite E45t-B4300 Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 Speakers Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 Speakers Replacement, Bottom Case: 步骤 3 中的图像 1,1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 Speakers Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 Speakers Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 Speakers Replacement: 步骤 6 中的图像 1,1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 Speakers Replacement, Speakers: 步骤 7 中的图像 1,1
    • Remove the two 7mm screws with a Phillips #0 screwdriver.
  8. Toshiba Satellite E45t-B4300 Speakers Replacement: 步骤 8 中的图像 1,1
    • Remove the following two 7mm screws with a Phillips #0 screwdriver
  9. Toshiba Satellite E45t-B4300 Speakers Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to disconnect the speakers from the motherboard.
    • Remove speakers.
结论
另外一个人完成了本指南。
Joshua Swanson
于02/20/17注册
701 声望
创作了6篇指南
团队
USF Tampa, Team S2-G2, Sullivan Spring 2017 USF Tampa, Team S2-G2, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S2G2
3 名成员
创作了12篇指南
2条评论
Where are these speakers available to buy
Paul T - 回复
I'm looking for it too (mine is a E45-B4200) but I only find fake ones.
At this point I'm going to try to fix the membrane with some kind of flexible glue.
MagenOne -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 490
