跳转到主内容
Toshiba Satellite E45t-B4204 Thermal Paste Replacement
你所需要的
  1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: 步骤 1 中的图像 1,3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: 步骤 1 中的图像 2,3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: 步骤 1 中的图像 3,3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 2 中的图像 2,2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 3 中的图像 3,3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: 步骤 4 中的图像 1,2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: 步骤 4 中的图像 2,2
    • Locate and remove the four 3 mm screws around the CPU.
    • The CPU is located beneath the copper heatsink.
  5. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the heatsink from the rest of the motherboard and casing.
  6. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: 步骤 6 中的图像 2,2
    • Now that the heatsink has been removed the CPU is visible. The CPU is the green square with silver metal in the center.
    • Reapply thermal paste above the CPU.
结论
Eduardo
于03/22/18注册
411 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 443
