跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This is a quick guide on how to replace the RAM of the Toshiba Satellite E45t-B4204. Replacing the RAM helps with speed and processing multiple tasks.
配件
没有特定配件。
  1. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Gently pull out the battery. Gently pull out the battery.
    • Gently pull out the battery.
  3. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  4. Lift up in the spaces left by the battery to create a gap between the back case and the laptop body. Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on. Remove the back case.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  5. Locate the RAM. The RAM will be covered by a black protective plastic. Once it is located, the protective plastic will be lifted up exposing the RAM. Locate the RAM. The RAM will be covered by a black protective plastic. Once it is located, the protective plastic will be lifted up exposing the RAM. Locate the RAM. The RAM will be covered by a black protective plastic. Once it is located, the protective plastic will be lifted up exposing the RAM.
    • Locate the RAM. The RAM will be covered by a black protective plastic. Once it is located, the protective plastic will be lifted up exposing the RAM.
  6. On the ends of the RAM, there are small clips. Click the small clips by pushing them away from from the RAM. Once the RAM has been clicked off gently pull out and remove. On the ends of the RAM, there are small clips. Click the small clips by pushing them away from from the RAM. Once the RAM has been clicked off gently pull out and remove. On the ends of the RAM, there are small clips. Click the small clips by pushing them away from from the RAM. Once the RAM has been clicked off gently pull out and remove.
    • On the ends of the RAM, there are small clips. Click the small clips by pushing them away from from the RAM. Once the RAM has been clicked off gently pull out and remove.
结论
Eduardo
于2018年03月22日注册
411 信誉积分
创作了4篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 18
总计 302
