跳转到主内容
Toshiba Satellite E45t-B4204 Keyboard Replacement
你所需要的
  1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: 步骤 1 中的图像 1,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: 步骤 1 中的图像 2,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: 步骤 1 中的图像 3,3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 2 中的图像 2,2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 3 中的图像 3,3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: 步骤 4 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 5 中的图像 2,2
    • Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo could potentially damage your device.
    • Remove speakers.
  6. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 6 中的图像 2,2
    • Unscrew 6 screws from the chassis with the Phillips #1 screwdriver.
  7. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 7 中的图像 2,2
    • Unscrew 8 screws from the motherboard using the Phillips #1 screwdriver.
  8. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 8 中的图像 2,2
    • Unplug wire from the motherboard.
  9. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 9 中的图像 1,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 9 中的图像 2,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 9 中的图像 3,3
    • Unscrew screws from the motherboard using the Phillips #1 screwdriver.
  10. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 10 中的图像 2,2
    • Unscrew screws from the CPU heat sink using the Phillips #1 screwdriver.
  11. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 11 中的图像 2,2
    • Unplug the wire from the motherboard.
    • Remove the heat sink.
  12. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 12 中的图像 2,2
    • Remove the CPU.
  13. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 13 中的图像 1,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 13 中的图像 2,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 13 中的图像 3,3
    • Unscrew the motherboard with the Phillips #1 screwdriver.
  14. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 14 中的图像 3,3
    • Remove the motherboard.
  15. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 15 中的图像 1,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 15 中的图像 2,3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 15 中的图像 3,3
    • Unscrew the keyboard cover using the Phillips #0 screwdriver.
    • Unscrew the keyboard cover using the #1 screwdriver.
  16. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 16 中的图像 1,1
    • Remove the keyboard cover.
  17. Toshiba Satellite E45t-B4204 Keyboard  Replacement: 步骤 17 中的图像 1,1
    • Remove the keyboard.
结论
Youdong Yan
于05/22/19注册
229 声望
撰写一个指南
团队
IUPUI, Team S3-G3, Wilson Summer 2019 IUPUI, Team S3-G3, Wilson Summer 2019 的会员
IUPUI-WILSON-SU19S3G3
4 名成员
创作了6篇指南
一条评论
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
Brent Murphy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 562
