跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This will be a quick guide on how to replace the fan of a Toshiba Satellite E45t-B4204. Replacing the fan will help prevent the device from overheating.
配件
没有特定配件。
  1. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver. Remove all 14 of the 4 mm screws on the back side of  the laptop with a Phillips #1 screwdriver.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Gently pull out the battery. Gently pull out the battery.
    • Gently pull out the battery.
  3. Lift up in the spaces left by the battery to create a gap between the back case and the laptop body. Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on. Remove the back case.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Locate the fan.
    • Locate the fan.
    • The fan is a grey plastic with a black circular fan in the center.
  6. Remove all 4 mm screws with a Phillips #1 screwdriver. Remove all 4 mm screws with a Phillips #1 screwdriver. Remove all 4 mm screws with a Phillips #1 screwdriver.
    • Remove all 4 mm screws with a Phillips #1 screwdriver.
  7. Locate the red, black, and yellow wire connecting to the motherboard. Locate the red, black, and yellow wire connecting to the motherboard.
    • Locate the red, black, and yellow wire connecting to the motherboard.
  8. Unplug the wire from the motherboard. Once it is unplugged you will remove the fan. Unplug the wire from the motherboard. Once it is unplugged you will remove the fan. Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
    • Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
结论
Perla Ruiz
于2018年03月22日注册
159 信誉积分
撰写一个指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 97
