跳转到主内容
Toshiba Satellite E45t-B4204 Charging Port Replacement
你所需要的
  1. Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: 步骤 1 中的图像 1,3 Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: 步骤 1 中的图像 2,3 Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: 步骤 1 中的图像 3,3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 3 中的图像 3,3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Charging Port Replacement, Charging Port: 步骤 4 中的图像 1,1
    • Locate the charging port housing.
  5. Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite E45t-B4204 Charging Port Replacement: 步骤 5 中的图像 3,3
    • Unplug the charging plug housing from the motherboard.
结论
Eduardo
于03/22/18注册
411 声望
创作了4篇指南
团队
一条评论
You didn’t complete the instructions. It ended after you said unplug the charging port housing. The pictures are not clear. Please add red lines or arrows, etc. to show what you are trying to do. It doesn’t show or spell out the next steps to replace it.
Correy Smith Hartzog - REALTOR - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 3,125
