简介
This is a quick guide on how to replace the charging port of a Toshiba Satellite E45t-B4204. Replacing the charging port can fix a charging port due to excessive use.
你所需要的
Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
即将完成!
结论
一条评论
You didn’t complete the instructions. It ended after you said unplug the charging port housing. The pictures are not clear. Please add red lines or arrows, etc. to show what you are trying to do. It doesn’t show or spell out the next steps to replace it.
