跳转到主内容
Toshiba Satellite E45t-A4300 Battery Replacement
你所需要的
  1. Toshiba Satellite E45t-A4300 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45t-A4300 Battery Replacement: 步骤 2 中的图像 1,1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45t-A4300 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery connector from the motherboard.
  4. Toshiba Satellite E45t-A4300 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the single screw Phillips #1 screw near the battery.
  5. Toshiba Satellite E45t-A4300 Battery Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite E45t-A4300 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the laptop.
结论
2等其他人完成本指南。
Jose Marques
于11/01/18注册
433 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G4
3 名成员
创作了14篇指南
3条评论
I did these steps and replaced the battery. Now my computer won’t turn on. No indicator lights, no fans, nothing. I tried to “reset” the battery (with the paper lip in the back. Didn’t work. So then I : unplugged everything held the power button down 60 seconds plugged the battery back in, no. Then I tried to disconnect the battery hold the power button down, plug the AC in [still no battery in it] and still nothing.
any ideas on what I did wrong or should check?
Rico - 回复
Again ask him for some pointers and see what he can tell you worse case scenario if you live in Boston or close by you can arrange an appointment with him drop your laptop. !&&* give you a receipt and if he cant fix it you get your money back as long as you have the receipt. He’s much better and far more experienced. You can also call me as well if you like.
Jose Marques -
Okay call me at 6175953020. I can try helping you. But worst case scenario you might have to take it to a professional computer technician. Sometime you have to properly @%^!* the whole system check the power input and see if its taking the power all theses things often a computer technician can do. I know this professional technician in Boston that I highly recommend and i can give you his number and he may be able to further troubleshoot it for you and help arrange a way in which you guys can fix it. I would highly recommend him he helped fix my computer when I was also having battery issues a while ago and he gets it done.
Here is his phone number : 617-288-9719
Jose Marques - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 32
总计 2,339
