跳转到主内容
Toshiba Satellite E45T-A4300 Motherboard Replacement
你所需要的
  1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Motherboard Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pull the hard drive out of the hook and remove it from the device.
  6. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: 步骤 6 中的图像 1,2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: 步骤 6 中的图像 2,2
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  7. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently disconnect the fan cable from the device.
  8. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
  9. Toshiba Satellite E45T-A4300 Motherboard Replacement, Heat Sink: 步骤 9 中的图像 1,1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  10. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
  11. Toshiba Satellite E45T-A4300 Motherboard Replacement, Battery: 步骤 11 中的图像 1,1
    • Disconnect the battery connector from the motherboard.
  12. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the single screw Phillips #1 screw near the battery.
  13. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 13 中的图像 1,2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the battery from the laptop.
  14. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: 步骤 14 中的图像 1,2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: 步骤 14 中的图像 2,2
    • Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
  15. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Pull metal stick holder until it is upright.
  16. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 16 中的图像 1,2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
  17. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 17 中的图像 1,3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 17 中的图像 2,3 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Disconnect the six connectors from the device.
    • For the monitor port, pull it from the black tab.
    • For the connection port with the blue strip, lift the white placeholder before pulling the blue strip out of the connection port.
  18. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 18 中的图像 1,2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Pull out 2 plugs out from the wireless network card.
  19. Toshiba Satellite E45T-A4300 Motherboard Replacement: 步骤 19 中的图像 1,1
    • Remove the motherboard from the device.
结论
James Nguyen
于10/23/18注册
573 声望
创作了5篇指南
团队
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 692
