跳转到主内容
Toshiba Satellite E45T-A4300 Heat Sink Replacement
你所需要的
  1. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 步骤 2 中的图像 1,1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Heat Sink: 步骤 3 中的图像 1,1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: 步骤 4 中的图像 3,3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
结论
James Nguyen
于10/23/18注册
573 声望
创作了5篇指南
团队
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 229
